poIExplosion GetID
Gets the explosion ID.
poIExplosion_handle GetID
HyperView Tcl Query
This command returns the explosion ID.
Error
Returns the explosion ID, or 0 if an error occurred.
View new features for HyperWorks Desktop 2020.1.
Gets the translation direction.
Gets the explosion label.
Gets a list of possible origin options.
Resets the exploded/translated parts back to their original position.
Sets the translation direction.
Sets the translation direction along a vector defined by at least two nodes.
Sets the explosion label.
Sets the mode to either explode or translate selected parts.
Specifies the selected components to be used by the control.
Applies the changes to the selected part to be exploded or translated.
ON THIS PAGE
HyperView Tcl Query
ON THIS PAGE
