poIExplosion GetMode
Gets the translation direction.
poIExplosion_handle GetMode
HyperView Tcl Query
This command returns the translation direction. Model - the model center is used as the explosion center. Selection - the center of the bounding box formed by the selected parts is used as the explosion center. Translate - allows selected parts to be translated/moved together.
Error
Returns the translation direction, or 0 if an error occurred.
