poIFBDCtrl SetTableMode
Sets the table mode.
poIFBDCtrl_handle SetTableMode context
HyperView Tcl Modify
This command sets the table mode (which is used for generating tables).
- context
- Boolean value. True if you need the table format or False if you do not.
Returns 0 if successful, otherwise an error code.
