poIFLDCtrl GetCategoryLabel
Gets the label of a particular band of the FLD zone category legend.
poIFLDCtrl GetCategoryLabel band_idx
HyperView Tcl Query
This command retrieves the label of a particular band of the FLD zone category legend.
band_idx
The index of the FLD legend band (valid values are 0,1,2,3,4,5).
To get the label of the 3rd band of FLD zone legend:
Note: The example below assumes that an FLD is currently plotted in a HyperView session.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetFLDCtrlHandle fld_ctrl
set lab [fld_ctrl GetCategoryLabel 2]
hwi CloseStack
Returns an empty string if there is an error.
