poIFLDCtrl SetCategoryLabel
Sets the label of a particular band of the FLD zone category legend.
poIFLDCtrl SetCategoryLabel band_idx label
HyperView Tcl Modify
This command sets the label of a particular band of the FLD zone category legend.
band_idx
The index of the color band (valid values are 0,1,2,3,4,5).
label
The label for the particular band.
To set the 3rd band of the FLD zone legend to "My Custom Label":
Note: The example below assumes that an FLD is currently plotted in a HyperView session.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetFLDCtrlHandle fld_ctrl
fld_ctrl SetCategoryLabel 2 “My Custom Label”
fld_ctrl SetEnableState true
client_handle Draw
hwi CloseStack
Error
Returns a non-zero value if there is an error.
