poIGraphicMaterial GetRoughness
Gets the roughness value of the graphic material.
graphic_material GetRoughness
HyperView Tcl Query
This command returns the roughness value of the graphic material (float 0.0 to 100.0).
To get the roughness value of a graphic material:
hwi OpenStack
session_handle GetClientManagerHandle post_manager_handle Animation
post_manager_handle GetGraphicMaterialHandle brass 3
brass GetRoughness
hwi CloseStack
None.
