poIGraphicMaterial SetRoughness
Sets the roughness value of the graphic material.
graphic_material SetRoughness value
HyperView Tcl Modify
This command sets the roughness value of the graphic material (float 0.0 to 100.0).
To set the roughness value of a graphic material:
hwi OpenStack
session_handle GetClientManagerHandle post_manager_handle Animation
post_manager_handle GetGraphicMaterialHandle brass 3
brass SetRoughness 30.0
hwi CloseStack
None.
