poIImagePlane GetLastFrameTracked
Gets the index of the last frame for which video tracking has been given.
Imageplane_handle GetLastFrameTracked
HyperView Tcl Query
The CalcVidTracking command gets data for each frame, however sometimes the tracking point is lost and no additional data is given after that point. This command returns the index of the last frame with data. Starting from the beginning, it gives the number of frames that have tracking data. After this many frames, the video will not be tracked.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle GetLastFrameTracked
hwi CloseStack
Returns HW_InvalidHandle if the image plane handle is invalid.
