poIImagePlane GetTrackingMode
Gets the current tracking mode for the image plane.
Imageplane_handle GetTrackingMode
HyperView Tcl Query
This command returns the current tracking mode for the image plane:
None
No tracking mode is enabled.
Model
The associated model ID determines which model is used to follow an active tracking system.
VideoMarker
The calculated marker tracking information is needed.
The tracking mode allows the image plane to follow a tracking system on a Model, or to follow the position of a marker in a video as it moves.
To get the current tracking mode:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle GetTrackingMode
hwi CloseStack
Error
Returns HW_InvalidHandle if the image plane handle is invalid.
