poIImagePlane GetVidTrackData
Gets the video tracking data used to track a point.
Imageplane_handle GetVidTrackData
HyperView Tcl Query
This command returns the video tracking data used to track a point. This is primarily used for creating session files. The string returned is in the form “x y X Y X Y X Y…..” , where x and y are floats for the pixel location of the tracking point and the remaining X's and Y's are the offsets per frame order from beginning to end.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle GetVidTrackData
hwi CloseStack
Returns HW_InvalidHandle if the image plane handle is invalid.
