poIImagePlane SetAlpha
Sets the alpha transparency associated with the image plane.
Imageplane_handle SetAlpha alpha
HyperView Tcl Modify
This command sets the alpha or transparency setting for the image plane. Allowed values are from 0 – 100, where 100 is completely opaque, and 0 is transparent. The transparency of an image plane in 3D mode is also affected by the cull angle settings.
Alpha
The new alpha setting.
To create two image planes, and then set the basic properties for one of them:
hwi OpenStack
if {[catch {
    session_handle GetProjectHandle project_handle
    project_handle GetPageHandle page_handle [project_handle GetActivePage]
    page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
    window_handle GetClientHandle client_handle
    client_handle GetImagePlaneCtrlHandle ipc_handle
    set ipid1 [ipc_handle AddImagePlane Logo1]
    ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
    imageplane_handle SetFileName g:/samples2/VideoOverlay/logo1.jpg
    imageplane_handle SetMode background
    imageplane_handle ReleaseHandle
    set ipid2 [ipc_handle AddImagePlane Video1]
    ipc_handle GetImagePlaneHandle imageplane_handle $ipid2
    imageplane_handle SetFileName g:/samples2/VideoOverlay/video1.jpg
    imageplane_handle SetLabel "Company Logo";
    imageplane_handle SetAlpha 80
    imageplane_handle SetMode foreground
    imageplane_handle SetAssociatedModelID 1
    imageplane_handle SetCullAngle 45
    imageplane_handle SetBackFaceVisibility true
    imageplane_handle SetCrop 0.2 0.2 0.8 0.8
    imageplane_handle SetStretchToFit false
    imageplane_handle SetMaintainAspectRatio false
    client_handle Draw
} result]} {
    global errorInfo;
    puts stderr $result;
    puts "[session_handle GetError]";
    puts stderr "*** Tcl TRACE ***";
    puts stderr $errorInfo;
} else {
    puts "No errors.";
    puts "Warnings: ";
    puts "    [session_handle GetError]";
hwi CloseStack
Returns HW_InvalidHandle if the image plane handle is invalid.
