poIImagePlaneCtrl RemoveImagePlane
Removes the specified image plane.
Imageplane_ctrl_handle RemoveImagePlane id
HyperView Tcl Modify
This command removes the specified image plane.
id
The unique ID of the image plane.
To create four image planes and then remove one of them:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
set ipid [ipc_handle AddImagePlane Logo1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid
imageplane_handle SetFileName g:/samples2/VideoOverlay/logo1.jpg
imageplane_handle SetMode background
imageplane_handle ReleaseHandle
set ipid [ipc_handle AddImagePlane Logo2]
imageplane_handle SetFileName g:/samples2/VideoOverlay/logo2.jpg
set ipid [ipc_handle AddImagePlane Video1]
imageplane_handle SetFileName g:/samples2/VideoOverlay/video1.jpg
set ipid [ipc_handle AddImagePlane Video2]
imageplane_handle SetFileName g:/samples2/VideoOverlay/video2.jpg
set Zlist [ipc_handle GetZOrderList background]
client_handle Draw
puts "The Z Order List is: $Zlist"
ipc_handle RemoveImagePlane 3
client_handle Draw
hwi CloseStack
Output:
The Z Order List is: 4 3 2 1
The Z Order List is: 4 2 1
Returns HW_InvalidHandle if the image plane control handle is invalid, or HW_IDNotFound if an image plane with the specified ID does not exist.
To obtain the error information, use GetError on the Session object as shown in the example.
