poIIsoValueCtrl GetAverageMode
Gets the method by which elemental results are averaged to nodes.
poIIsoValueCtrl_handle GetAverageMode
HyperView Tcl Query
This command retrieves the method by which elemental results are averaged to nodes. Possible return values are: none, simple, maximum, minimum, advanced, difference, Max of corner, Min of corner, or Extreme of corner.
None.
