poIIsoValueCtrl GetDataComponent
Gets the current data component for the given dimension.
poIIsoValueCtrl_handle GetDataComponent dim
HyperView Tcl Query
This command retrieves the current data component for the given dimension.
- dim
- The given dimension. Options include "node", "line", "shell", or "solid".
Returns the component label.
