poIIsoValueCtrl GetIgnoredFlippedNormal
Gets the state of the "Ignore Flipped Normal" option set for the feature angle average.
iso_handle GetIgnoreFlippedNormal
HyperView Tcl Query
This command returns the state of the "Ignore Flipped Normal" option set for the feature angle average.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetIsoValueCtrlHandle iso_handle
# Get the Ignore Flipped Normal state
if {[iso_handle GetFeatureAngleAverageEnableState] == true } {
set flipped_normal [iso_handle GetIgnoreFlippedNormal]
hwi CloseStack
Returns a Boolean value (True or False).
