poIIsoValueCtrl SetDataComponent
Sets the data component for a given component.
poIIsoValueCtrl_handle SetDataComponent dim comp_label
HyperView Tcl Modify
- dim
- The component dimension. Options include: "node", "line", "shell", or "solid".
- comp_label
- The component label.
Returns 0 if successful, otherwise an error code.
