poIIsoValueCtrl SetDimensionEnabled
Sets the dimension state: enabled or disabled.
poIIsoValueCtrl_handle SetDimensionEnabled dim_label state
HyperView Tcl Modify
This command sets the dimension state: enabled or disabled.
dim_label
The dimension state label: "line", "shell", or "solid".
state
True if enabled, false if not.
Returns 0 if successful, otherwise an error code.
