poIIsoValueCtrl SetEnabled
Sets the dimension state, either enabled or disabled.
poIIsoValueCtrl_handle SetEnabled pool state
HyperView Tcl Modify
This command sets the dimension state: enabled or disabled.
pool
The pool from which to set the enable state.
state
True if enabled, or false if not enabled.
Returns 0 if successful, otherwise an error code.
