poIIsoValueCtrl SetLegendMode
Sets the legend mode to true or false.
poIIsoValueCtrl_handle SetLegendMode state
HyperView Tcl Modify
This command sets the legend mode to true or false.
Note: If legend mode is set to true, then a contour has to be applied before generating the iso value. In this case, multiple iso values will be generated.
state
Set to true to generate multiple iso values, or false to generate single iso values.
Returns 0 if successful, otherwise an error code.
