poIIsoValueCtrl SetShellLayer
Sets the current shell layer.
poIIsoValueCtrl_handle SetShellLayer layer
HyperView Tcl Modify
This command sets the current layer.
Note: The scalar storage within HyperView can accept a shell layer or a derived quantity of all shell layers (max, min, or extreme).
layer
The shell layer label or one of the following derived types:
max
Stores the maximum value of all layers.
min
Stores the minimum value of all layers.
extreme
Stores the maximum absolute values of all layers.
Returns 0 if successful, otherwise an error code.
