poIMeasure AddMinDistFromSet
Adds the entity set used as the "from" set.
poIMeasure_handle AddMinDistFromSet set_id_str
HyperView Tcl Modify
This command will supply the measure object with the selection set containing the entities (components/elements/nodes) that will be used as the “from” side for minimum distance computation.
set_id_str
The identifier for the selection set.
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page page_id
page GetWindowHandle window win_id
window GetClientHandle post
post GetMeasureHandle mindist measure_id
mindist AddMinDistFromSet set_id_str
Returns 0 if successful, otherwise an error code.
