poIMeasure IsItemLinked
Gets if the measure item is dynamically linked to a curve or not.
poIMeasure_handle IsItemLinked
HyperView Tcl Query
This command retrieves if the measure item is dynamically linked to a curve or not.
Returns the link status: true if the measure item is dynamically linked to the curve, or false if the measure item is not dynamically linked to the curve.
