poIModel DefineAssembly
Defines an assembly in a model.
poIModel_handle DefineAssembly assemblyID label parentAssemblyID
HyperView Tcl Modify
This command defines an assembly in a model.
assemblyID
The ID of the new assembly to be defined.
label
The name of the new assembly.
parentAssemblyID
The ID of the parent assembly (already existing in the model).
To define a new assembly with the ID 1 and the label assembly:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myModelName DefineAssembly 1 assembly1 0
Returns 0 if successful, or an error code (HW_IDNotFound) - if the specified parent assembly is not found in the model or
(HW_InvalidHandle) - if the handle used to invoke the method is no longer valid.
