poIModel GetEntityInfo
Returns the property information for a given entity.
model_handle GetEntityInfo entity property entityid
HyperView Tcl Query
This command returns information regarding the requested property. The possible values for the "property" argument depend upon the "entity" argument.
entity
The possible values for this argument are "node" or "element".
property
For a "node" entity type, the property argument may have a value of "coord".
For an "element" entity type, the property argument may have values of "normal" or "centroid".
entityid
The entity id for which the property is requested.
To create several selection sets on the current model and request a selection set list:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
# Get Information about the node coordinates, element centroid, element normals
model_handle GetEntityInfo node coord “Node 500”
model_handle GetEntityInfo element centroid “Shell 156”
model_handle GetEntityInfo element normal “Shell 100”
hwi CloseStack
Returns "error" if an invalid entity type/property combination is passed.
