poIModel GetMaterial
Gets the component material ID (zero if none assigned). If this is an assembly, -1 is always returned.
poIModel_handle GetMaterial
HyperView Tcl Query
This command returns the component material ID (zero if none assigned). If this is an assembly, -1 is always returned.
None.
