poIModel GetMeshMode
Gets the component's mesh mode. If this is an assembly, ALL child parts must be set to the same mesh mode, otherwise the returned mode will be "none".
poIModel_handle GetMeshMode
HyperView Tcl Query
This command returns the component's mesh mode (edges, features, meshlines, or none). If this is an assembly, ALL child parts must be set to the same mesh mode, otherwise the returned mode will be "none".
None.
