poIModel GetSelectionSetList
This command retrieves a list of all selection set IDs on the current model.
model_handle GetSelectionSetList poolname
HyperView Tcl Query
This command retrieves a list of selection set IDs on the current model. Particular selection sets can be accessed with these IDs as keys.
poolname (Optional)
The name of the set pool for which the ID list is requested.
To create several selection sets on the current model and request a selection set list:
Note: If the optional poolname argument is not provided, the ID list from all of the set pools will be returned.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
set id [model_handle AddSelectionSet component]
model_handle GetSelectionSetHandle selection_set_handle $id
selection_set_handle SetLabel "OurSelectionSet1"
selection_set_handle Add all
puts "SelectionSet: [selection_set_handle GetLabel] "
puts "    [selection_set_handle GetSize] [selection_set_handle GetType]s"
selection_set_handle ReleaseHandle
set id2 [model_handle AddSelectionSet element]
model_handle GetSelectionSetHandle selection_set_handle $id2
selection_set_handle SetLabel "OurSelectionSet2"
selection_set_handle Add "id 1-100"
set id3 [model_handle AddSelectionSet element]
model_handle GetSelectionSetHandle selection_set_handle $id3
selection_set_handle SetLabel "OurSelectionSet3"
selection_set_handle Add "selectionset == $id2"
puts "Current Selection Sets: [model_handle GetSelectionSetList]"
model_handle RemoveSelectionSet $id
puts "Selection Set $id removed…"
hwi CloseStack
This command does not return any errors.
