poIModel GetTranslation
Gets the translation vector in the global coordinate system. If this component is an assembly, a zero translation will always be returned.
poIModel_handle GetTranslation
HyperView Tcl Query
This command returns the translation vector in the global coordinate system. If this component is an assembly, a zero translation will always be returned.
None.
