poIModel SetAssemblyID
Sets the parent to the assembly identified by assy_id. This will always fail. You cannot change the model's parent.
poIModel_handle SetAssemblyID assy_id
HyperView Tcl Modify
This command sets the parent to the assembly identified by assy_id. This will always fail. You cannot change the model's parent.
- assy_id
- The assembly ID to move this part/assembly into.
Returns 0 if successful, otherwise an error code.
