poIModel SetTranslation
Sets the translation vector in the global coordinate system. If this component is an assembly, a zero translation will always be returned. Translating/exploding the root level (model) assembly is an invalid operation. The translation will be put into a TRANSLATION mode explosion.
poIModel_handle SetTranslation translation_vector
HyperView Tcl Modify
This command sets the translation vector in the global coordinate system. If this component is an assembly, a zero translation will always be returned. Translating/exploding the root level (model) assembly is an invalid operation. The translation will be put into a TRANSLATION mode explosion.
translation_vector
The translation vector.
Returns 0 if successful, otherwise an error code.
