poINote GetScreenAnchor
Gets whether or not the note is anchored.
note_handle GetScreenAnchor
HyperView Tcl Query
This command retrieves the current anchor state of the note.
To find out if note id 2 is anchored to the screen or not, use the following:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetNoteHandle note_handle 2;
set bool_anchor [note_handle GetScreenAnchor];
hwi CloseStack
Returns "true" if the note is anchored to the screen, or "false" if the note is not anchored to the screen.
