poINote SetPositionToAttachment
Controls the leader length of the note.
note_handle SetPositionToAttachment true/false
HyperView Tcl Modify
If “true” is passed to this command, the lower left corner of the bounding box of the note will be positioned at the attachment point. The attachment location could be on the node, the element centroid, or the part centroid - depending upon the entity type to which the note is attached.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetNoteHandle note_handle 2;
# Turn on "SetPositionToAttachment" option
note_handle SetPositionToAttachment true;
# Turn off "SetPositionToAttachment" option
note_handle SetPositionToAttachment false;
hwi CloseStack
This command returns (0) if successful, or a "non-zero value" if an error occurred.
