poINote SetText
Sets the note text.
poINote_handle SetText note
HyperView Tcl Modify
This command sets the note text.
- note
- The note text.
Error
Returns 0 if successful, otherwise an error code.
View new features for HyperWorks Desktop 2020.1.
Gets the note text alignment.
Gets the note attachment method.
Gets the list of entity types to which a note can be attached.
Gets the note auto-hide status. Auto-hidden notes will not display if the attachment point is occluded.
Gets the background/fill color of the note.
Gets the text border thickness.
Gets the bounding box of the note.
Gets the note text color index.
Gets the expanded/evaluated version of the text for a note, if it contains any Templex statements.
Gets the list of valid field names for a note.
Gets the font name being used to draw the note in the graphics area.
Gets a handle to an hwIFont interface for the font of the note.
Gets the height of the bounding box of the note.
Gets the label of the note.
Gets the name of the note.
Gets the note position.
Gets whether or not the note is positioned at the attachment location.
Gets whether or not the note is anchored.
Gets the current shape of the note.
Gets the note text.
Gets the transparency attribute value (true/false).
Gets the note visibility.
Gets the width of the bounding box of the note.
Sets the text alignment for the note.
Sets the note attachment method.
Sets the note auto-hide attribute.
Sets the background/fill color for the note.
Sets the note border thickness.
Sets the note border and leader line color.
Sets the font by name.
Sets the note label.
Sets the note position.
Controls the leader length of the note.
Anchors the note at its current position.
Sets the current shape of the note.
Sets the note text.
Sets the transparency attribute value (true/false).
Sets the note visibility.
Sets the note text.
ON THIS PAGE
Sets the note text.
ON THIS PAGE
