poIPart GetRelativeTo
Gets the positions relative to the parent assembly, local or global.
poIPart_handle GetRelativeTo id_string
HyperView Tcl Query
This command retrieves the positions relative to the parent assembly, local or global.
- id_string
- Global, local or a marker ID string that belongs to the same assembly as the part.
Returns 0 if successful, otherwise an error code.
