poIPart SetDefaultColor
Sets the part default color index.
poIPart_handle SetDefaultColor str
HyperView Tcl Modify
This command sets the part default color index. Generally, only the standard color commands should be used. The default color commands are used by the model reading code to control what was used as the default color (as opposed to the user set color).
str
The color identifier string.
Returns 0 if successful, otherwise an error code.
