poIPart SetEulerAngles
Sets the Euler angles (Z-X-Z) with respect to the system defined by the call to poIModel SetRelativeTo.
poIPart_handle SetEulerAngles str
HyperView Tcl Modify
This command sets the Euler angles (Z-X-Z) with respect to the system defined by the call to poIModel SetRelativeTo.
str
The color identifier string.
Returns 0 if successful, otherwise an error code.
