poIPart SetOrientation
Sets the part's orientation in the local coordinate system by the given Euler angles ZXZ.
poIPart_handle SetOrientation str
HyperView Tcl Modify
This command sets the part's orientation in the local coordinate system by the given Euler angles ZXZ.
str
The color identifier string.
Returns 0 if successful, otherwise an error code.
