poIPost AddQueryRule
Adds the query rule to the advanced query.
client_handle AddQueryRule rule
HyperView Tcl Modify
This command adds the query rule to the advanced query.
- rule
- Accepts only the following: expression, extreme, mindist, ignoreelemtype, and selectionset.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule mindist]
client GetQueryRuleHandle rule_handle $ruleID
hwi CloseStack
This command returns 0
, if an invalid string is passed to the rule.
