poIPost AddResultMathAnalysis
Adds a model and result pair to HyperView and enables result math.
poIPost_handle AddResultMathAnalysis tmpl mfile rfile mreader rreader add_resfiles
HyperView Tcl Modify
- tmpl
- The result module template name (for example, Standard, Advanced, NVH).
- mfile
- The path of the model file.
- rfile
- The path of the result file.
- mreader (Optional)
- Specifies the reader name which will be used to read the model file.
- rreader (Optional)
- Specifies the reader name which will be used to read the result file.
- add_resfiles (Optional)
- Specifies the path of additional result files to be loaded along with the model file and result file. The additional result files are separated by a semicolon (;).
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle AddResultMathAnalysis Standard c:/model.dat c:/result.op2 0 0 “c:/result2.op2;c:/result3.op2;c:/result3.op2”
hwi CloseStack
Returns the ID of the model added, or an error code (0) if a model/result pair could not be added.
