poIPost CaptureImageByRegion
Renders a specific region of the current HyperView window to an off-screen image.
poIPost_handle CaptureImageByRegion regionType filename quality
HyperView Tcl Modify
This command renders the current HyperView window, crops the rendering to the specified region, and then writes it to an off-screen image.
regionType
The region of the window which will be saved. MODELSONLY specifies that the window will be cropped so that only the models will be visible.
filename
The name of the file.
quality
The image quality (1-4, with 1 as the default).
To render the current HyperView window and specify that the window will be cropped so that only the models are visible:
variable t [expr rand()];
hwi GetActiveCleintHandle post$t
post$t CaptureImageByRegion MODELSONLY C:/image.jpg 4
post$t ReleaseHandle
Error
Returns 0 if successful, otherwise an error code.
