poIPost Clear
Resets the current post instance by removing all models and resetting the view (as well as any other post state).
poIPost_handle Clear
HyperView Tcl Modify
This command resets the current post instance by removing all models and resetting the view (as well as any other post state).
Returns 0 if successful, otherwise an error code.
