poIPost CopyResult
Copies a result definition from another definition.
post_handle CopyResult id context notify
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, copies a result definition from another definition. It also returns the ID of the created result definition.
- id
- The result definition label ID to copy from.
- context
- A string indicating the context of the result to copy (scalar, tensor, vector, iso).
- notify
- Set to 'true' to trigger an event to update the browser, otherwise 'false'. The default value is true.
To copy the vector result with ID 5:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client CopyResult 5 vector true
hwi CloseStack
Returns 0 if there was an error copying the result and sets an error condition on the session handle. See session_handle GetError.
Related Topics
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
