poIPost GetBestViewHandle
Gets the handle of the best view.
post_handle GetBestViewHandle param id
HyperView Tcl Query
This command gets the handle of the best views present in the current post client with a given ID.
param
Specify a handle name.
id
Specify the ID of the best view for which the handle is needed.
To get the handle of the best view for the newly created best view:
post_handle GetBestViewHandle bestview_handle [post_handle AddBestView]
To get the handle of the best view already created in the post client:
post_handle GetBestViewHandle bestview_handle 10
This command returns the handle name if successful or an error code.
