poIPost GetResultReaderList
Gets a list of result readers for a given result file. If no filename is given, then all result readers are returned.
poIPost_handle GetResultReaderList filename
HyperView Tcl Query
This command retrieves a list of result readers for a given result file. If no filename is given, then all result readers are returned.
- filename (Optional)
- The result file name.
Returns 0 if successful, otherwise an error code.
