poIPost GetSectionDeformFrame
If deformable sections are active, the interpolation frame, which was active when the section was cut, becomes planar.
poIPost_handle GetSectionDeformFrame
HyperView Tcl Query
Note: This command is applicable when HyperView is in interpolation mode.
Returns the interpolation frame when the section mode was changed to deformable.
