poIPost GetSectionDeformTime
Gets the time at which the section mode was changed to deformable.
poIPost_handle GetSectionDeformTime
HyperView Tcl Query
This command retrieves the time at which the section mode was changed to deformable. If deformable sections are active, the time at which the section was cut is planar.
Note: This command is applicable when HyperView is in transient mode.
Returns the time at which the section mode was changed to deformable.
