poIPost RemoveBestView
Removes the BestView.
client_handle RemoveBestView id
HyperView Tcl Modify
This command removes the BestView with a specified ID.
id
The ID of the BestView already existing in the post handle.
To remove BestViews from a given advanced query result:
post_handle RemoveBestView 1
This command returns 0 if successful, otherwise and error code.
