poIPost RemoveGraphicMaterial
Removes the graphical material from the database.
poIPost_handle RemoveGraphicMaterial id
HyperView Tcl Modify
This command removes the graphical material from the database.
id
The graphic material ID to remove.
Returns 0 if successful, otherwise an error code.
