poIPost WaitForResults
Causes the application to wait for all of the results of the given type to load before returning.
post_handle WaitForResults type
HyperView Tcl Query
This command, valid only in Upfront Data Loading Mode, causes the application to wait for all of the results of the given type to load before returning. If type is not specified, then it will wait for all of the types to finish loading before returning. It can be used as a sync point for scripting.
type
Optional argument specifying the type of data to wait for. Valid values are: scalar, vector, tensor, simulation, or iso.
To wait for scalar results to finish loading before returning:
hwi OpenStack
hwi GetSessionHandle sess
sess GetClientManagerHandle mgr animation
mgr WaitForResults scalar
hwi CloseStack
Returns error code and sets error condition on the session handle. See session_handle GetError.
