poIPostManager GetGlobalPropertyValue
Gets the global property value.
poIPostManager_handle GetGlobalPropertyValue property
HyperView Tcl Query
This command returns the value for a particular global property.
- property
- The name of the available global property.
hwi OpenStack
session_handle GetClientManagerHandle manager_handle Animation;
manager_handle GetGlobalPropertyList
manager_handle GetGlobalPropertyValue “Convert 2nd order elements to 1st order elements”
hwi CloseStack
This command returns empty string, if there are no global options.
